Z1000J Clutch Pushrod
Coose
#1 PostAuthor: Coose » Tue May 30, 2017 5:31 pm
Evening all,
Before I buy a new one, does anyone have an unworn clutch pushrod for a Z1000J kicking about?
Coose
martinz1000r
Re: Z1000J Clutch Pushrod
#2 PostAuthor: martinz1000r » Wed May 31, 2017 9:22 am
I have one. Can you measure the one you need as i am not sure if it's Unitrak or J/R/GPz B.
You can make your own from silver steel rod. See recent post by ZedHead
Coose
#3 PostAuthor: Coose » Wed May 31, 2017 9:30 am
Ahhhh dagnabbit, the part numbers are different of J and Unitrak. That's annoying....
I'll drop it out once I get the chance. What would you be asking for it, and does it have much wear?
martinz1000r
#4 PostAuthor: martinz1000r » Wed May 31, 2017 12:32 pm
I have 3 in the draw....
All different lengths!
Number 1 - looks genuine Kawasaki 300mm long. Perfect. £10 posted
Number 2 - looks home made. 310mm long. Perfect condition except some minor corrosion where one end exposed to the air. £5 posted
Number 3 - Looks home made 330mm. Surface corrosion where sat in a drawer but will clean up. £5 posted
Let me know if any of these work. I suspect length differences are to cover hydraulic clutch conversions over the years.
Coose
#5 PostAuthor: Coose » Thu Jun 01, 2017 4:45 pm
Cheers old chap. Mine is 335mm long, so I think I'll hang on to see if anyone has a genuine one but I might just take you up on the offer of the longer one. :)
big green bus
#6 PostAuthor: big green bus » Sun Jun 11, 2017 2:29 pm
you can buy stainless steel ground bar the right diameter just cut it to the right length
