Hi all,
Above not working on z1a .The bulb is ok , the switch seems ok when it was removed .There's plenty of oil pressure. Any clues
oil pressure light / switch
- PETER KZ1A
Re: oil pressure light / switch
It is most likely to be either the wiring within the warning lights, or the oil pressure switch. If not then check earths, and wiring for continuity.
Touch the wire from the switch to the engine block with ignition on,if the lamp goes out you have a faulty switch or lack of oil pressure,low oil,faulty pump ,blocked oil pump filter etc
PAULJAC47 wrote:Touch the wire from the switch to the engine block with ignition on,if the lamp goes out you have a faulty switch or lack of oil pressure,low oil,faulty pump ,blocked oil pump filter etc
Is it not the other way around Paul, the switch is in the earth return from the bulb meaning earthing the wire will light the bulb. If this happens you know you have a faulty switch. If the bulb stays out you have a loom bulb issue.
Julian_Boolean
Definitely that way round on J engines - you find these things out when you make your own wiring loom.
Yes you are right Dave ,keeping on eye on me lately eh...? lol
PAULJAC47 wrote:Yes you are right Dave ,keeping on eye on me lately eh...? lol
Just glad to get something right for a change Paul
- PETER KZ1A
Thanks for the replies. Touched the wire from the switch to the block and the oil pressure light comes on . Must be a stuffed switch .
Well that's a nice easy fix and a good bit of info regarding how the switch works on the J motors etc.which by the sounds of it not a lot of us knew that!
Users browsing this forum: Bing [Bot], ZZR1993 and 152 guests
