Hi Guys,
As the title says I am on the lookout for the rear indicator/grabrail mounting pressings from a z1000A frame.
Would consider a damaged frame, or a rear sub-frame removed for a special build, with them still attached.
Thanks,
Mark.
Rear frame indicator mounts
- ZedHead
Mark.
Mark.
- ZedHead
Re: Rear frame indicator mounts
hi mark would a z1000 ltd frame be any use to you ?
I used a set off a dead 250 the indicator holes are the same but they needed positioned.
Once they're on they look okay depends how pedantic you are...
Actually I think I subsequently found the ones I originally cut off twenty five years ago, they may still be in a drawer in the garage ... I'll have a look.
- ZedHead
Not very, it's a LTD and it looks like they were chewed off!!
Actually I think I subsequently found the ones I originally cut off twenty five years ago, they may still be in a drawer in the garage ... I'll have a look.[/quote]
That would be great, I've sent you the money for the seat, if you find them I'll send you a few quids more and hope you could put them in the same parcel.
Mark.
Mark.
Got these if you get desperate. Just took a while to find them. They're not equal heights but you could trim one down maybe.
Z1000A2 I think.
Gus
Z1000A2 I think.
Gus
"Set the GRINDER on it"
Users browsing this forum: Google [Bot] and 28 guests
