Z1100R ELR Parts Wanted
z1000puddin
#1 PostAuthor: z1000puddin » Sun Jul 09, 2017 6:33 pm
Guys
I need a few parts for this ELR project..
Nose fairing , original or Pattern
Instrument clock assy
Starter motor
Ignition & key ( I think Martinz1000r has me sorted here)
Side stand bracket ( maybe one out there, saves me fabrication )
Stu
Zed til Dead
Robw
Re: Z1100R ELR Parts Wanted
#2 PostAuthor: Robw » Sun Jul 09, 2017 7:14 pm
I have a combined speedo and rev counter in the large binacle, if that's the clock style you are after.
Rob
z1000puddin
#3 PostAuthor: z1000puddin » Sun Jul 09, 2017 7:34 pm
Rob
Have you got a picture,?
I believe this is the type.
I'm not 100% Sure, the bike I have is a 1985 model
Stu
Zed til Dead
Julian_Boolean
#4 PostAuthor: Julian_Boolean » Sun Jul 09, 2017 8:07 pm
I've got a Skidmarx fibreglass fairing I'm not going to use, if you get Rob's clocks we could combine postage as he lives not far from me.
#5 PostAuthor: Al » Sun Jul 09, 2017 8:10 pm
I have just cut down the massive clunky J style (3 spring affair) bracket on mine to fit a zx636 stand from a breaker on ebay. If youre not worried about originality you could get the stand and bracket from similar and just weld it on.
z1000puddin
#6 PostAuthor: z1000puddin » Sun Jul 09, 2017 8:23 pm
Julian_Boolean wrote:I've got a Skidmarx fibreglass fairing I'm not going to use, if you get Rob's clocks we could combine postage as he lives not far from me.
Julian
Is the fairing close resemblance to the original & does it have a screen ?
Would it marry up with Robs clocks ?
We can do a deal with the V&H exhaust,
There are 2 small dents
On the down pipes.
The badge is a little worn.
Stu
Zed til Dead
z1000puddin
#7 PostAuthor: z1000puddin » Sun Jul 09, 2017 8:28 pm
Al wrote:I have just cut down the massive clunky J style (3 spring affair) bracket on mine to fit a zx636 stand from a breaker on ebay. If youre not worried about originality you could get the stand and bracket from similar and just weld it on.
I have the side stand, just not the bracket .
It is the simple single spring type.
I have access to plenty of Fabrication, machine shop & welding,so to have a bracket fabricated is no big issue , just if someone had a gash frame with a bracket, it would save a bit of time. :D
Stu
Zed til Dead
Robw
#8 PostAuthor: Robw » Sun Jul 09, 2017 8:30 pm
Stu, that's the style of clocks I have. Send me your email address and I will forward some pictures to you.
Rob
z1000puddin
#9 PostAuthor: z1000puddin » Sun Jul 09, 2017 8:43 pm
Rob
Email sent
That's what I love about this site .
So many guys willing to help out ....
Stu
Zed til Dead
swampy
#10 PostAuthor: swampy » Sun Jul 09, 2017 8:51 pm
I may have a fairing bracket knocking around if you need one. But i will have to check.
z1000puddin
#11 PostAuthor: z1000puddin » Sun Jul 09, 2017 9:10 pm
swampy wrote:I may have a fairing bracket knocking around if you need one. But i will have to check.
Thanks Swampy,
If you can check, appreciate it
Stu
Zed til Dead
#12 PostAuthor: ZedHead » Sun Jul 09, 2017 9:33 pm
I am interested to find out how good the Skidmarx ones are too.
chrisw1
#13 PostAuthor: chrisw1 » Sun Jul 09, 2017 10:26 pm
if it helps the GPZ750R1 fairing is the same ( I think ) apart from the last digit of the part umber which defines the colour
They are slightly easier to find
Robw
#14 PostAuthor: Robw » Mon Jul 10, 2017 7:21 am
Skidmark ones are excellent quality and got. I have one fitted to my Lawson.
Rob
Julian_Boolean
#15 PostAuthor: Julian_Boolean » Mon Jul 10, 2017 8:17 am
As Rob says the fairing is the same shape as the original and has a black screen, it's a little tatty and was mounted using the Skidmarx brackets, happy to do a deal with the Vance and Hines exhaust.
This is it on my bike
