Hi, wot is the torque setting for cylinder head bolts on z900 a4 and the tightening sequence please
Chris
Cylinder head
Cylinder head
73 z1, z650c3
ALWAYS LOOK ON THE BRIGHT SIDE OF LIFE
Re: Cylinder head
25 to 32 ft/lb on the stock studs and up to 42 ft/lb with HD studs.
For torqueing down you need to work evenly outwards fore,aft,left,right from the middle to the outer nuts in at least 3 stages of around 10 ft/lb increments up to the chosen figure.
- ZedHead
Re: Cylinder head
Starting from the front left (looking down from above) and moving clockwise.
12/10/6/2/4/8/M6 bolt/9/5/1/3/7/11/M6 bolt
Tighten in two stages first to 18ft-lbs (2.5kg-m)
Then to 27-31ft-lbs (3.7-4.3kg-m)
Tighten the M6 bolts last to 95-113in-lbs (1.1-1.3kg-m)
Users browsing this forum: r3sc and 36 guests
