Will fit J motors of all different varieties including; 1000R and 1100R/Unitrak and 1100B and others but not strictly correct for 1100R/Unitrak as this is the early cover.
Clean straight early cover with working stator bolted and properly sealed into it. Stator is about five years old but has seen little use.
RR14 Reg Rec bought from Electrex World on Tuesday this week for £66. Fitted and run for a day on Thursday. Now surplus to requirements. Will have receipt with Tuesdays' date and is guaranteed for 12 months.
Alternator rotor from my J. Good straight and un-damaged. Has polishing round the edge where the wiring tab was not fitted correctly. Has a good taper with very little scoring / galling but will lap on perfectly well. No broken or damaged magnets, all threads good. Original Kokusan not the aftermarket ones with the keyway in them
£40 for the cover / stator
£33 for RR14 Reg rec
£120 for Rotor.
£175 if you take all three
Postage extra in each case
J charging system
J charging system
LeeJackson
Re: J charging system
Pm sent
