Battery choice
DavidZ1R
Battery choice
#1 PostAuthor: DavidZ1R » Thu Jul 27, 2017 5:26 pm
I put a temporary battery on my z1000a1, surprised every thing worked fine, so looking to put a new battery on, should I stick to the yuasa, go for an enduro , or what is the favoured opinion, what should I avoid. Cheers
Re: Battery choice
#2 PostAuthor: z1bman » Thu Jul 27, 2017 5:40 pm
i would fit one of these but check compatibility first
http://www.saisei-europe.com/Shop/Produ ... gm-battery
jonhunt
Re: Battery choice
#3 PostAuthor: jonhunt » Thu Jul 27, 2017 6:36 pm
Just fitted an Excel from MCP sees good
Coose
Re: Battery choice
#4 PostAuthor: Coose » Fri Jul 28, 2017 12:23 am
Yuasa, every time...
wheelysteve
Re: Battery choice
#5 PostAuthor: wheelysteve » Fri Jul 28, 2017 11:03 am
I've just put one of these Yuasa gel batteries on my Z1B. Not quite as powerful as a motobatt, but identical in size to the original Yuasa, no maintenance, no acid to drip on my expensive exhausts and it's not YELLOW !!
Decent price from Halfords as well....
http://www.yuasabatteries.com/battery.p ... 71&vID=175
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: Battery choice
#6 PostAuthor: ADRIAN H » Fri Jul 28, 2017 6:33 pm
wheelysteve wrote:I've just put one of these Yuasa gel batteries on my Z1B. http://www.yuasabatteries.com/battery.p ... 71&vID=175
+ 1 The correct answer
King of Kings
Re: Battery choice
#7 PostAuthor: King of Kings » Fri Jul 28, 2017 9:54 pm
Fitted a MotoBatt well over 9 years ago, still going strong!
Fred the Zed
Re: Battery choice
#8 PostAuthor: Fred the Zed » Sat Jul 29, 2017 5:17 pm
I like Motobatt. Always fires up first prod of the starter....... (ok, might be helped by Dyna ignition, Dyna Coils, Taylor leads, Iridium plugs, new switchgear and loom...)
Fred
Paid Up Member
DavidZ1R
Re: Battery choice
#9 PostAuthor: DavidZ1R » Sat Jul 29, 2017 5:28 pm
Yep I'm going for motobatt, it's ordered
Fred the Zed
Re: Battery choice
#10 PostAuthor: Fred the Zed » Sun Jul 30, 2017 9:37 am
DavidZ1R wrote:Yep I'm going for motobatt, it's ordered
I think you'll be impressed.
Fred
Paid Up Member
Re: Battery choice
#11 PostAuthor: chrisu » Sun Jul 30, 2017 11:18 am
do not let a motobatt run completely flat - it will bugger it.
don't ask me how i know.
swampy
Re: Battery choice
#12 PostAuthor: swampy » Sun Jul 30, 2017 7:41 pm
also you can now get them in black apparently.
Re: Battery choice
#13 PostAuthor: ADRIAN H » Sun Jul 30, 2017 8:55 pm
chrisu wrote:do not let a motobatt run completely flat - it will bugger it.
+ 1 have done the same. Plus they're YELLOW.
steve-g
Re: Battery choice
#14 PostAuthor: steve-g » Mon Jul 31, 2017 8:42 am
Just fitted a motobatt to my ST and it's black.
Zed man
Re: Battery choice
#15 PostAuthor: Zed man » Mon Jul 31, 2017 11:28 am
Word of warning..... when you lay the bike up over winter, DON'T USE A normal battery charger... will fry the battery.. motobatt do a trickle charger called baby boy, and there about £20 quid.. & there yellow too.. 70amps cranking power..
