I have a set of 70mm wiseco pistons with gudgeon pins for sale barely used one has a new second ring on, spare oil rings and a top ring with them. £115- posted.
Also a box of other bits mainly casings and one and a half gearbox clusters, these are free to any one that wishes to collect from Wisbech.
There will also be a thou crank available at some stage.
70 mm wiseco pistons, and other parts
Re: 70 mm wiseco pistons, and other parts
Hi Kev,
If the casings etc. are still available, can I please have.
Regards.
Phil
Regards.
Phil
Kev, I could use the gearbox clusters if your not in a rush to get rid.
I will be going to grumpys to pick a head up soon ish, I could pick these up on the way!
Phil
Phil
