GPZ1100 B1 FUEL TANK
as above cash waiting
						Re: GPZ1100 B1 FUEL TANK
Hi, I have one happy to move on.
jovin04 was looking for one and I was chatting to him about it. I have not heard anything for nearly a week now so if interested pm me.
Cheers, Matt
Cheers, Matt
Matt C
Z1000J2 / ZRX1200R / Z650B1 / GPz1170B1 x 2
Hi mate  do you still have the b1 tank and how much are you after for it.
cheers Ian
						cheers Ian
Yes I do. I have sent you a pm
Matt
									Matt
Matt C
Hey Ian, I did send you a pm.....did you not get it?
Matt
									Matt
Matt C
Hi,
Is this tank now sold?
If not, then what condition is it, and does it come with fuel tap & level sensor?
Ricky
Ricky
H2B  GPZ900R
Not sold Ricky....I never heard back from previous interested party.
The tank has no good fuel taps although I might have one or two knocking around that could be cleaned up. It looks like the tap position on the RHS has been moved forward at some point in the past.
It needs a round base fuel sender not the elongated version. I "might" have a dubious one somewhere if you cannot get anywhere else.
Tank does not leak I am pretty sure as it was on a non-working bike I bought on ebay with a weird oil/fuel mix in it for 12 months.
The inside would need a good clean out.
Matt C
I actually have a 1000J with the US style tank at the moment.
Odd, but when I had a J back in the day I always preferred the rounder US version tank, but now I'm not so sure!
Presume I'd just need to blank off the fuel return hole to fit it on the standard carb J model?
Can you PM me a price?
H2B  GPZ900R
To use on  J with carbs you would need to check whether the fuel tap mounting (that looks like it has been moved) is still in the right place...or move it  back. When I bought this tank on a bike, it just had a bolt plus fibre washer blanking off the return hole. The fuel tap on my J has the elongated hole for the filter and two M6 bolt holes that goes with the vacuum tap. You could use the B1 style tap that does not have the vacuum control. A number of options really....use a pingel....etc
If I have a fuel sender it will probably be a bit corroded and need new wiring and clean up as a min.
I will have a look tomorrow
Sending pm re the price
Matt
Matt
Matt C
I have a skanky one I'm looking to shift.
Thanks, but I've done a deal for the tank with Matt now.
Do you have any of the accessories? (fuel tap, filler cap, gauge sender, badges, etc)
H2B  GPZ900R
Matt,
Like the spec of your J2
Did the 1105 pistons go into a bored out J block, or did you need a GPz one?
I ended up putting GPz pistons in my original J (back in the 80s) after I managed to seize the oil scraper rings on the 2 middle pistons during a spirited ride !
H2B  GPZ900R
rickm wrote:I have a skanky one I'm looking to shift
It has the tap, return and sender but that may be 100% of the value of the tank.
I used the standard block from the J to go to 1105cc.
I think if you want to bigger then you would probably need the 1080cc block off the GPz1100b1
Matt C
