Oil burn
jonhunt
Oil burn
#1 PostAuthor: jonhunt » Mon Aug 28, 2017 5:47 pm
I get a short burst of black smoke as I accelerate. I think this is a sign that the valve stem seal are less than efficient. They are probably the originals so no surprise. Doesn't smoke at steady speed or idle
Re: Oil burn
#2 PostAuthor: kev edwards » Mon Aug 28, 2017 6:17 pm
Black smoke is usually associated with unburnt fuel, oil is normally blue, I would look at fuelling.
jonhunt
Re: Oil burn
#3 PostAuthor: jonhunt » Mon Aug 28, 2017 9:00 pm
I laid her up for a couple of years maybe a sticky float
Re: Oil burn
#4 PostAuthor: chrisu » Tue Aug 29, 2017 8:28 pm
Good to see you're back on the bike
jonhunt
Re: Oil burn
#5 PostAuthor: jonhunt » Wed Aug 30, 2017 2:35 pm
Thanks Chris
The carbs initially p?&@ed fuel out from the T joints after the first petrol fill. That's stopped now. Fuel consumption seems high. Other than that she seems to run well. I'll take her round my mates and see what he thinks
Re: Oil burn
#6 PostAuthor: Pigford » Wed Aug 30, 2017 3:25 pm
jonhunt wrote:Thanks Chris
As above..... BLACK = FUEL (usually) especially as you say bad mpg! WHITE/BLUE = OIL
KeithZ1R
Re: Oil burn
#7 PostAuthor: KeithZ1R » Thu Aug 31, 2017 8:45 am
will we see yous at Tewsbury next weekend ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
jonhunt
Re: Oil burn
#8 PostAuthor: jonhunt » Thu Aug 31, 2017 2:26 pm
At a concert in Bristol on Saturday so probably not. Do you mean the lower lode?
