Fork oil????
Wrigers
Fork oil????
#1 PostAuthor: Wrigers » Thu Sep 07, 2017 9:48 am
Hi folks just a quicky 're fork oil refill on a 900 A4.
I haven't got myself a manual yet so I need to know the oil capacity for each leg and the recommended type used. The legs aŕe off the bike , so what is the best method to use for refilling , i take it you remove the top leg bolts and refill from there. Paul.
Re: Fork oil????
#2 PostAuthor: chrisu » Thu Sep 07, 2017 6:01 pm
yes - just take the top cap off and tip old oil out.
refill with 175cc of 10w oil or 15w if you want it a bit stiffer
BigZCas
Re: Fork oil????
#3 PostAuthor: BigZCas » Thu Sep 07, 2017 7:31 pm
You may find it easier to re-assemble once your stanchions are clamped back into the yokes, especially if the springs take some compressing when refitting top fork nuts :)
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Wrigers
Re: Fork oil????
#4 PostAuthor: Wrigers » Fri Sep 08, 2017 11:46 am
Thanks both. Good advise.
Users browsing this forum: No registered users and 83 guests
