help
robertthomson
help
#1 PostAuthor: robertthomson » Mon Oct 23, 2017 11:02 am
Hi Gang ... I'm based in Welwyn Herts and recently have imported a KZ900A its not running well at all (not sure its firing on all cylinders) and also the carbs leak if the fuel is left on when the bikes not running, anyone know of any good local mechanics that really know their way around a Z1
KeithZ1R
Re: help
#2 PostAuthor: KeithZ1R » Mon Oct 23, 2017 12:13 pm
Hello Robert see you made it :up there is a bunch of guys in your area so sombody will be along presently with your info
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Re: help
#3 PostAuthor: chrisu » Mon Oct 23, 2017 2:09 pm
I'm in Hertford if you want to message me and we can take a look. I've sent you a pm.
pertonpc
Re: help
#4 PostAuthor: pertonpc » Mon Oct 23, 2017 2:20 pm
Gravity fuel tap is best turned off when bike not running - more prone to leaks than later vacuum taps.
Someone gave me a tip to turn the tap off a little while before you park up in garage - to let it drain the bowls a bit.
If it is just weeping from one or more carb overflow pipes and not all it is usually a bit of muck stopping the needle valve seating right.
All above are fairly common & nowt to worry about.
From Mark
Users browsing this forum: Google [Bot] and 64 guests
