Z1000 A1 rear master cylinder
AJAyre
#1 PostAuthor: AJAyre » Mon Oct 23, 2017 5:56 pm
Evening all
can anyone tell me what sze bolt and washer 5 and 6 are on the A1 rear master cylinder it’s one of the missing items from the jigsaw I’m rebuilding and typically is discontinued an neither Z Power nor CMS have any stock
Re: Z1000 A1 rear master cylinder
#2 PostAuthor: chrisu » Mon Oct 23, 2017 6:45 pm
I can have a look tomorrow
update: sorry - i thought i had some spare master cylinders but can't find them.
Blackseven
#3 PostAuthor: Blackseven » Fri Oct 27, 2017 11:00 am
I think I’ve got a spare bolt and washer from a scrap rear master cylinder if you want it. Can’t post until next Tuesday morning though as out of the country. Rob
AJAyre
#4 PostAuthor: AJAyre » Sun Oct 29, 2017 8:26 pm
Rob that would be fantastic i’ll Pm you
Blackseven
#5 PostAuthor: Blackseven » Mon Oct 30, 2017 5:57 pm
Hi, yes, I've found the correct bolt/plug
Not sure if you'll be able to PM me as I've only just registered here and not joined Z1OC yet - I will!
If you want to text me your address on 07710 648800 I'll get it in the post to you tomorrow.
Rob
AJAyre
#6 PostAuthor: AJAyre » Thu Nov 02, 2017 7:27 pm
Rob
Many thanks for the bolt another problem solved
Regards
Adrian
