Cam cahin tensioner removal
I need to swap my starter motor but the adjusting bolt on the tensioner is longer than standard meaning i can"t remove the motor without taking the tensioner bolt right out or removing the tensioner body. Can anyone tell me if I will be at risk of the cam chain going so slack as to maybe drop off the crankshaft? Is there a way of keeping tension on the chain so as not to risk disturbing the cam timing? Thanks team!
Re: Cam cahin tensioner removal
You will be ok removing the tensioner bolt as long as you don't rotate the engine until it's put back in.
i'd set the engine to TDC as well..........
ok thanks guys. I have seen a lip on the outside end of the tapered shaft which i thought may mean that loosening the bolt was ok but removing it wasn't.
Hi ChrisB
what kind of bike do you have?
If it's a bike with a manual chain tensioner take a look at the point of the bolt. It should be sharpened a bit if it isn't.
If it's a bike with an automatic chain tensioner ( Z1000 MK2, H or ST) find yourself a bolt of the correct lenght!
When you put the bolt back in: don't overdo it, you could crack the tensioner or damage the thread inside.
Good luck!
Greetings from Belgium
Good luck!
That's the problem, Phillipe. Someone has used a bolt which is too long. I'll put in a more suitable bolt when i do the job!
It's as much about finding the time to get in to my garage!
It's a Z1000A1 by the way, so an automatic tensioner.
it wouldn't be an automatic tensioner on a z1000 a1 unless someone has changed it the automatic tensioners where only introduced on the mk11 engine & onwards
- warren3200gt
my A1 is manual.
this is the bolt for the automatic tensioner
- Attachments
- s-l1000.jpg (87.8 KiB) Viewed 5410 times
this is what you should have for the a1 manual tensioner
- Attachments
- s-l300.jpg (18.49 KiB) Viewed 5410 times
yep, that's what i 'should' have. What i've got is a 30-45mm allen headed M6 bolt!
Hi Chris
when nobody changed the tensioner in the past, your's should not be an automatic but a manually operated one.
When it's a manual operated tensioner, the lenght of the bolt doesn't matter, only the point should be a little sharper.
Try to figure that out.
Good luck
Good luck
