Z1R large fuel tank fuel cap
I am also after a fuel cap for the large tank model, does anyone have one that they might consider selling or again are there any other suppliers out there?
Re: Z1R large fuel tank fuel cap
Is there a difference to the 'STD' size tank?
Small tank is about 13 litres and large tank holds another gallon or so. The large tank also has a central filler as opposed to the off set one on the small tank
Not an expert on the Z1R...and this will probably show that....isn't the actual 'cap' the same?
No unfortunately not
Haggler wrote:I am also after a fuel cap for the large tank model, does anyone have one that they might consider selling or again are there any other suppliers out there?
which tank is it for uk up grade or a d2-d3 tanks as there diffo heres a d3 on ebay now
https://www.ebay.com/itm/1980-Kawasaki- ... jW&vxp=mtr
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
compo z1r wrote:Haggler wrote:I am also after a fuel cap for the large tank model, does anyone have one that they might consider selling or again are there any other suppliers out there?
which tank is it for uk up grade or a d2-d3 tanks as there diffo heres a d3 on ebay now![]()
Cheers compo thats the one
If you are already aware of this then I apologise in advance.
If you filler looks like this :-
then the cap on ebay will be ok .......however :-
if it looks like this :-
then it most certainly will not
just a "heads up" that is usefull information to bank.
As an aside I have noticed over recent years that Z1R tanks of all available sizes are appearing from all types of places usually without a Tank cap ??????
It begs questions A: what happened to all the small tanks and caps that where "discarded" by dealers when the belated "upgrade " was fitted because the two caps are TOTALLY different. B: what happend to the caps off the various type of Tanks that are" coming out of the woodwork" because they dont fit anything else FFS! mebe they turned them into Christmastree ornaments
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
[quote="KeithZ1R"]If you are already aware of this then I apologise in advance.
I did ask if its up grade or d2-d3
then dont waste your money
Keith
mistaken.
mistaken.
Advice accepted gratefully. Thinking about maybe cutting in a filler neck from a different model now
Managed to secure a cap, mind it is still attached to the tank it comes with. Well I needed it
