timing
ogre
timing
#1 PostAuthor: ogre » Tue Nov 07, 2017 6:08 pm
hi all got z1a its running so i thought i would put strobe light on it to check. its got boyer bransden ignition plugged into no4 plug and its showing 2/3 on advance so swapped wires round from coil into box and its still showing 2/3 on advance plate not 1/4 any ideas what im doing wrong.
thanks trev
Re: timing
#2 PostAuthor: PAULJAC47 » Tue Nov 07, 2017 6:13 pm
Sure you are on plug 4 lead? one coil feeds 1 and 4 the two outer pots,the other coil feeds 2 and 3 the two inner pots,trace hts back to coil outputs.
Re: timing
#3 PostAuthor: z1bman » Tue Nov 07, 2017 7:02 pm
your not wired up rite
Re: timing
#4 PostAuthor: z1bman » Tue Nov 07, 2017 7:06 pm
check the low tension wires. coil 1+4 = black. & yellow& red stripe
2+3 coil green. & yellow & red stripe
ogre
Re: timing
#5 PostAuthor: ogre » Tue Nov 07, 2017 10:03 pm
so there are black and green wires comin out of boyer box so connected to coils then swapped the green and black coil wires round still the same weird
wheelysteve
Re: timing
#6 PostAuthor: wheelysteve » Tue Nov 07, 2017 10:21 pm
Not sure how the Boyer thing works, but you would get this on the standard set up if the points cam was fitted 180 deg out.
That would mean removing the bolt from the advance unit and turn the cam and refitting.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: timing
#7 PostAuthor: kev edwards » Wed Nov 08, 2017 7:45 am
You can go on to the Boyer website and print off the fitting instructions, i am not 100% sure but i think on some of the kits all four plugs fire at the same time, there was/is an issue with rotor positioning due to the way Kawasaki made things.
ogre
Re: timing
#8 PostAuthor: ogre » Wed Nov 08, 2017 2:54 pm
It does run and tick over but it drops u rev it and goes up again the boyer system isnt new it was on bike when i bought it so prob quite a few years old .one thing i did notice i get 12.5 volts with ignition on to coils if i disconnect the the power lead to the box .if i connect it i only get 11 ish volts goin to coils just wondering if its had it and maybe better goin to points
