GPZ1100 Frame
GPZ1100 Frame
Is it possible to fit a Z900/1000 engine into a gpz1100 frame?
foz
									foz
				Julian_Boolean
Re: GPZ1100 Frame
I pretty sure you can but someone will be along to say for definite.
Why do you want to do it?
						Re: GPZ1100 Frame
It's not easy. I had the same idea with a Unitrak frame but when I positioned the Z900 crankcases in the frame it was obvious it was going to be a challenge. So I gave up but someone on here has done it. The front mount is way off and needs repositioning as I recall.
Here's the project http://z1ownersclub.co.uk/phpBB3/viewtopic.php?f=7&t=24650
A2 1979-80. A1 1980-now
						Re: GPZ1100 Frame
I am thinking of going the other way has anybody done the reverse, GPZ into z1000/900 frame it must be possible as non kickstart engines should be shorter.
If anyone has pics or tips it would be useful.
Re: GPZ1100 Frame
should be easy to put a GPz in.
I had a Harris made for a Z900...blew that up and put a GPz in. Can't remember there being any issues.
Re: GPZ1100 Frame
Done rather a long time ago.
From memory the front and rear top mounts are a straight fit.
We welded another tube across the front with ears on to fit the lower mount.
And I "think" we welded ears on to the swing arm cross tube for the rear lower mount
Gus
Gus
"Set the GRINDER on it"
				Julian_Boolean
Re: GPZ1100 Frame
There isn't a lower rear engine mount on a GPZ1100 engine (or any J engine), the front lower is an additional one to the older engines, front mountings are rubber, rear is solid
						Re: GPZ1100 Frame
I was looking to use a GPZ1100 frame, as there is a complete lack of Z900/1000 frames out there for sensible money - anyone got one to sell? I read the project threads and its not a straight forward swop. I've been offered a frame and crankcases, so could I transplant a Z900 engine internals into GPZ1100 crankcase?
foz
									foz
						Re: GPZ1100 Frame
There was a z1r frame for sale on here yesterday. You would be better buying that. I used to run a z1r tank on an a1 so bodywork should not be a problem.
I think an engine internals transfer would be difficult.
You can fit gpz heads to earlier engines but gearbox clutch cranks etc i suspect would not work.
Re: GPZ1100 Frame
The Z!R frame would work, but I cant see it posted, can you highlight for me?
foz
									foz
						Re: GPZ1100 Frame
Plus. old zed tanks won't fit a GPz frame..the tubes are spaced much wider.
						Re: GPZ1100 Frame
Julian_Boolean wrote:There isn't a lower rear engine mount on a GPZ1100 engine (or any J engine), the front lower is an additional one to the older engines, front mountings are rubber, rear is solid
That proves how long ago it was done and the last time I looked at it
Gus
						Re: GPZ1100 Frame
FOZ1A wrote:The Z!R frame would work, but I cant see it posted, can you highlight for me?
foz
Member trogg 41
viewtopic.php?f=3&t=42006
Gus
						Re: GPZ1100 Frame
As Gus says below, but i emailed and pm'd you last night.
						Re: GPZ1100 Frame
FOZ1A wrote:I was looking to use a GPZ1100 frame, as there is a complete lack of Z900/1000 frames out there for sensible money - anyone got one to sell? I read the project threads and its not a straight forward swop. I've been offered a frame and crankcases, so could I transplant a Z900 engine internals into GPZ1100 crankcase?
foz
Thats my ongoing project... Not far off now just need to find some time and enthusiasm.
Years ago I put a GPZ1100 crank, cylinders and head in to a Z900 engine for my Harris but you have to weld the supports for the rear cam chain guide into the top crankcase so the reverse is possible.
Phil.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
