GPZ1100 Frame
FOZ1A
GPZ1100 Frame
#1 PostAuthor: FOZ1A » Sat Nov 11, 2017 5:51 pm
Is it possible to fit a Z900/1000 engine into a gpz1100 frame?
foz
Julian_Boolean
Re: GPZ1100 Frame
#2 PostAuthor: Julian_Boolean » Sat Nov 11, 2017 9:14 pm
I pretty sure you can but someone will be along to say for definite.
Why do you want to do it?
popsA1
Re: GPZ1100 Frame
#3 PostAuthor: popsA1 » Sat Nov 11, 2017 10:32 pm
It's not easy. I had the same idea with a Unitrak frame but when I positioned the Z900 crankcases in the frame it was obvious it was going to be a challenge. So I gave up but someone on here has done it. The front mount is way off and needs repositioning as I recall.
Here's the project http://z1ownersclub.co.uk/phpBB3/viewtopic.php?f=7&t=24650
A2 1979-80. A1 1980-now
KWACKERZ1
Re: GPZ1100 Frame
#4 PostAuthor: KWACKERZ1 » Sun Nov 12, 2017 5:25 pm
I am thinking of going the other way has anybody done the reverse, GPZ into z1000/900 frame it must be possible as non kickstart engines should be shorter.
If anyone has pics or tips it would be useful.
garyd
Re: GPZ1100 Frame
#5 PostAuthor: garyd » Mon Nov 13, 2017 5:57 pm
should be easy to put a GPz in.
I had a Harris made for a Z900...blew that up and put a GPz in. Can't remember there being any issues.
Gus
Re: GPZ1100 Frame
#6 PostAuthor: Gus » Mon Nov 13, 2017 6:30 pm
Done rather a long time ago.
From memory the front and rear top mounts are a straight fit.
We welded another tube across the front with ears on to fit the lower mount.
And I "think" we welded ears on to the swing arm cross tube for the rear lower mount
Gus
"Set the GRINDER on it"
Julian_Boolean
Re: GPZ1100 Frame
#7 PostAuthor: Julian_Boolean » Mon Nov 13, 2017 9:02 pm
There isn't a lower rear engine mount on a GPZ1100 engine (or any J engine), the front lower is an additional one to the older engines, front mountings are rubber, rear is solid
FOZ1A
Re: GPZ1100 Frame
#8 PostAuthor: FOZ1A » Tue Nov 14, 2017 8:50 am
I was looking to use a GPZ1100 frame, as there is a complete lack of Z900/1000 frames out there for sensible money - anyone got one to sell? I read the project threads and its not a straight forward swop. I've been offered a frame and crankcases, so could I transplant a Z900 engine internals into GPZ1100 crankcase?
foz
KWACKERZ1
Re: GPZ1100 Frame
#9 PostAuthor: KWACKERZ1 » Tue Nov 14, 2017 12:38 pm
There was a z1r frame for sale on here yesterday. You would be better buying that. I used to run a z1r tank on an a1 so bodywork should not be a problem.
I think an engine internals transfer would be difficult.
You can fit gpz heads to earlier engines but gearbox clutch cranks etc i suspect would not work.
FOZ1A
Re: GPZ1100 Frame
#10 PostAuthor: FOZ1A » Tue Nov 14, 2017 2:42 pm
The Z!R frame would work, but I cant see it posted, can you highlight for me?
foz
garyd
Re: GPZ1100 Frame
#11 PostAuthor: garyd » Tue Nov 14, 2017 6:45 pm
Plus. old zed tanks won't fit a GPz frame..the tubes are spaced much wider.
Gus
Re: GPZ1100 Frame
#12 PostAuthor: Gus » Tue Nov 14, 2017 9:14 pm
Julian_Boolean wrote:There isn't a lower rear engine mount on a GPZ1100 engine (or any J engine), the front lower is an additional one to the older engines, front mountings are rubber, rear is solid
That proves how long ago it was done and the last time I looked at it :roll: :lol:
Gus
Gus
Re: GPZ1100 Frame
#13 PostAuthor: Gus » Tue Nov 14, 2017 9:15 pm
FOZ1A wrote:The Z!R frame would work, but I cant see it posted, can you highlight for me?
foz
Member trogg 41
viewtopic.php?f=3&t=42006
Gus
KWACKERZ1
Re: GPZ1100 Frame
#14 PostAuthor: KWACKERZ1 » Wed Nov 15, 2017 9:35 am
As Gus says below, but i emailed and pm'd you last night.
zpower
Re: GPZ1100 Frame
#15 PostAuthor: zpower » Thu Nov 16, 2017 12:38 pm
FOZ1A wrote:I was looking to use a GPZ1100 frame, as there is a complete lack of Z900/1000 frames out there for sensible money - anyone got one to sell? I read the project threads and its not a straight forward swop. I've been offered a frame and crankcases, so could I transplant a Z900 engine internals into GPZ1100 crankcase?
foz
Thats my ongoing project... Not far off now just need to find some time and enthusiasm.
Years ago I put a GPZ1100 crank, cylinders and head in to a Z900 engine for my Harris but you have to weld the supports for the rear cam chain guide into the top crankcase so the reverse is possible.
Phil.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
Users browsing this forum: No registered users and 96 guests
