Uk specification
chrisw1
Uk specification
#1 PostAuthor: chrisw1 » Fri Dec 01, 2017 10:29 pm
Good Evening
I am looking to build my Z1B project to UK spec
I have the chrome bits , the UK fork reflectors and the seat with the strap . I need some shock absorbers without reflectors but I have seen repro ones .
Do I use a short stem rear indicator ?
Are there any other features I need to know about ?
Thanks Chris
proj 53.JPG (100.24 KiB) Viewed 8194 times
wheelysteve
Re: Uk specification
#2 PostAuthor: wheelysteve » Fri Dec 01, 2017 10:47 pm
The grab rail in the photo is for a Z900 A4 UK model. The Z1B has the std hand rail.
UK specific bits are front forks with chrome discs not reflectors, rear shocks with no reflectors, long rear fender with no reflectors, rear light mounting to suit the long fender, seat with strap, headlight with side light and Euro chrome bezel, left hand switchgear with flasher. Probably more but I'm in the pub at the minute and my poor memory is being adversely affected!
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
chrisw1
#3 PostAuthor: chrisw1 » Sat Dec 02, 2017 12:53 am
All good stuff to know Steve , I have been told that the UK Z1B had the indicators on the grab rail but I could be mistaken of course
000zeds
#4 PostAuthor: 000zeds » Sat Dec 02, 2017 7:28 am
UK Z1B did not have indicators on grab rail and I don`t think any from USA did :!:
Zeds-R-Us
chrisw1
#5 PostAuthor: chrisw1 » Sat Dec 02, 2017 7:53 am
Good news there then , the grab rail without indicator mounts is much nicer
Thanks folks
walshyco
#6 PostAuthor: walshyco » Sat Dec 02, 2017 8:02 am
I think the U.K. models had a long “mudguard “ and the US Models had a short “fender”
BigZCas
#7 PostAuthor: BigZCas » Sat Dec 02, 2017 8:53 am
Ok here we go, this is what I've found on mine and after doing some research :)
None of the Z1 models had indicators mounted on the grab rail nor a reflector on the Long rear guard.
Other subtle differences -
Koito front light with single chrome rim and sidelight.
The RH Switch had the PO painted to suit.
A resistor was bolted to a bracket under the RH coil to stop the bulb blowing.
Flasher on LH Switch
Chrome front discs on forks
No reflectors on rear shocks.
Seat Strap.
Long Rear Guard
The decal on the tray in the tailpiece had (European Model).
The headstock frame decal (silver) was not used but all had to carry the E11 10R 241 interference decal.
And the hardest to change -
The UK destined bikes had a slightly different bottom yolk, housing a UK specific Steering Lock (sits flush).
The steering lock key was not a Lion key.
This may also help if looking to buy a UK model. :)
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
floydsz1
#8 PostAuthor: floydsz1 » Sat Dec 02, 2017 9:11 am
If anyone needs any of these I make them out of stainless.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
#9 PostAuthor: Garry.L » Sat Dec 02, 2017 9:17 am
UK models had metal plug caps. VERY pricey IF you can find them.
Indicator lenses were different front to rear (IIRC clearer front than rear).
UK models were also faster.
BigZCas
#10 PostAuthor: BigZCas » Sat Dec 02, 2017 9:30 am
Yes,
I only have 1 of the rear frosted type :evil:
Anyone got one to sell ? :) (STANLEY 29949) 045 6692
Yes, I know that I have asked before ??
Metal plug caps, I just added some grey shrinkwrap, They will do :lol:
Past 5 Years
1976 KZ1000a1, Red
#11 PostAuthor: ZedHead » Sat Dec 02, 2017 9:55 am
Solid front foot pegs and different rubber pattern.
There are loads of subtle differences it is worth getting a good book. I think John Brookes one is one of the best.
BigZCas
#12 PostAuthor: BigZCas » Sat Dec 02, 2017 10:13 am
Rubbers as supplied by you Dave :D
Past 5 Years
1976 KZ1000a1, Red
wheelysteve
#13 PostAuthor: wheelysteve » Sat Dec 02, 2017 10:28 am
Oh I missed a few bits while under the influence last night !!
[quote="BigZCas"]Yes,
Steve, I think there is frosted indicator lens with this lot here....
https://www.ebay.co.uk/itm/Kawasaki-Z65 ... SwFp9aIUCG
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
BigZCas
#14 PostAuthor: BigZCas » Sat Dec 02, 2017 11:06 am
Thank you Steve,
Well Spotted :D
Past 5 Years
1976 KZ1000a1, Red
A1John
#15 PostAuthor: A1John » Sat Dec 02, 2017 1:09 pm
My Uk spec z1b has folding front footrests, single headlamp rim with a Stanley headlamp lens, grab rail with indicator mounts,long rear guard no holes, frosted rear indicator lens, chrome blanks on front forks, Nippondenso grey shaft plug caps, Seat strap,UK/Euro steering lock.plastic body master cylinder, plain rear shocks.
