Anybody have any tips for removing the needle roller bearings from a Z1000 swingarm. They are seized in. Not even a hint of grease in the swingarm tube so these things are well corroded in place.
Currently soaking in a tray of WD40.
Swingarm Bearing Removal
- wheelysteve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: Swingarm Bearing Removal
I use a blind bearing puller with a slide hammer, can loan it to you if needed
Hi Steve
the needle bearings are gone anyway and you'll have to replace them(2 or 4 depending on the model A1 or A2)
If the swingarm needs a new coat of paint I would suggest you heat it at the location of the bearings and tap out the bearings with a long piece of steel and a hammer. Be carefull not to damage the swingarm!
Once they're out you can clean the inner portion of the swingarm and remove the rust. Repaint it, put new bearings and plenty of grease in and off you go.
Good Luck!
Good Luck!
Bearing puller is the better way.
- ZedHead
Be animal, you can't save them. I've had to grind a groove through the outer on some particularly stubborn ones. Press, slide hammers, drifts erc all failed.
Mark.
Mark.
- wheelysteve
OK, a mixture of my engineering skills
, my collection of watchmakers hammers, chisel, grinders and brute force has saved the day.
Mostly brute force actually
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
