Worn or Worn Out?
Blackseven
Worn or Worn Out?
#1 PostAuthor: Blackseven » Sat Jan 06, 2018 8:00 pm
I started to reassemble the bottom end of my engine and gearbox today and noticed some strange looking wear on the input shaft first gear (the one that is part of the shaft). I've tried to attach a photo - the wear actually looks a lot worse in the photo than real life but there are little ridges on the face of each tooth that can be felt with a finger nail so I presume the shaft should be replaced? All of the other gears look fine including the corresponding first gear on the layshaft.
Has anyone come across this before? Has anyone got a decent input shaft they want to sell for a Z1000A1/2? I've seen one one Ebay listed as a Z1/Z900/Z1000 shaft but are they all exactly the same?
Thanks! Rob
Re: Worn or Worn Out?
#2 PostAuthor: z1bman » Sat Jan 06, 2018 8:23 pm
the shaft is fitted to all these models
KZ1000-A1 KZ1000 (1977)
KZ1000-A2 KZ1000 (1978)
KZ1000-A2A KZ1000 (1978)
KZ1000-A3 KZ1000 (1979)
KZ1000-A3A KZ1000 (1979)
KZ1000-A4 KZ1000 (1980)
KZ1000-B1 KZ1000 LTD (1977)
KZ1000-B2 KZ1000 LTD (1978)
KZ1000-B3 KZ1000 LTD (1979)
KZ1000-B4 LTD (1980)
KZ1000-C1 Police 1000 (1978)
KZ1000-C1A Police 1000 (1978)
KZ1000-C2 Police 1000 (1979)
KZ1000-C3 Police 1000 (1980)
KZ1000-C4 Police 1000 (1981)
KZ1000-D1 Z1R (1978)
KZ1000-D3 Z1R (1980)
KZ1000-G1 Classic (1980)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 LTD (1976)
Z1 Z1 (1973)
Z1-A Z1 (1974)
Z1-B Z1 (1975)
#3 PostAuthor: ADRIAN H » Sat Jan 06, 2018 8:25 pm
I Don’t know much about gear shafts. But that shaft does look mullered.
popsA1
#4 PostAuthor: popsA1 » Sat Jan 06, 2018 10:15 pm
It's difficult to tell from the photo but I'd guess there's an imperfection in the hardening causing the the surface to break up.
Either way, you need a fresh one.
And if the corresponding output gear shows any ware marks l'd replace it as well.
A2 1979-80. A1 1980-now
Blackseven
#5 PostAuthor: Blackseven » Sat Jan 06, 2018 10:47 pm
Thanks all - good advice, I'm on the trail of a replacement shaft.
Rob
Mr Bump
#6 PostAuthor: Mr Bump » Sun Jan 07, 2018 7:50 am
I’ve probably got one, Ive got a whole gearbox less I think fifth gear cogs. I’ll have a look in my stash later on.
Olly
Lemmy
Blackseven
#7 PostAuthor: Blackseven » Sun Jan 07, 2018 11:01 am
Cheers Olly that would be great.
Rob
Mr Bump
#8 PostAuthor: Mr Bump » Sun Jan 07, 2018 8:47 pm
Hello mister,
Had a look - the spare one I’ve got is showing similar wear, though possibly not quite as bad. I guess it’s not an uncommon issue.
According to t’internet its adhesive wear, the marks are caused by the two load bearing faces momentarily welding together under load, likely caused by poor lubrication. Crap oil then, or car engine oil maybe?
Anyway, you are welcome to my gearbox bits if you want them, tho expect you’ll want to find something mint if you can.
Olly
Lemmy
Blackseven
#9 PostAuthor: Blackseven » Sun Jan 07, 2018 11:44 pm
Thanks for the offer but I’ll look out for something with no wear on the tooth faces.
Rob
Users browsing this forum: Google [Bot] and 106 guests
