Z1B back from the dead
saltflatracer
- Regular Poster
Re: Z1B back from the dead
Did you get the frame checked at Maidstone Motoliner if so how much did they charge you ?
saltflatracer wrote:Did you get the frame checked at Maidstone Motoliner if so how much did they charge you ?
I used a guy in St Helens .it was £150
saltflatracer
- Regular Poster
thank you
Good progress today .... bottom half of engine fitted , swing arm bushed and fitted , shocks on , forks and yokes etc in
Fitted the rear guard but forgot to fit the seat lock so had to take it all off again and do that , healamp bucket and indicator stems along with battery box etc
Made another list of parts that I forgot to get so will sort that this week
Oddly my caliper is a right one which means I might as well go for twin discs leaves me looking for a left and another disc or sell off the right and buy a repro left
I don't like the look of polished fork legs so had them vapour blasted and lacquered ..... not sure if I like them yet
Sorry for the picture quality its the fluorescents in the workshop
- Attachments
- proj 66.JPG (75.92 KiB) Viewed 8988 times
- proj 65.JPG (78.1 KiB) Viewed 8988 times
- proj 64.JPG (88.56 KiB) Viewed 8988 times
- proj 63.JPG (87.01 KiB) Viewed 8988 times
Sell off the right caliper + disc and buy the twin disc kit from Z-Power if you can afford it
Zeds-R-Us
Hello Chris,
I had my fork legs ball burnished and then gave them a light CAREFUL rub with a ultra fine Scotch Brite pad.
Really like the finish, looks very similar to original but with no lacquer.
On another note: I'm not a fan of the indicators on the grab rail type, when you have the Z1 oval rear light, only my opinion
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Laced up the wheels with some after market rims .... I do have some original coded ones but the costs are getting away from me
Trueing them up and watching telly ....... very relaxing
- Attachments
- proj 67.JPG (84.46 KiB) Viewed 8950 times
What do you keep in the cellar?????
(trap door)
(trap door)
wheels trued up and assembled ...I used the same finish on the brake plate ( vapour and laquer )
I think it looks quite smart now
- Attachments
- proj 69.JPG (89.34 KiB) Viewed 8934 times
- proj 68.JPG (108.97 KiB) Viewed 8934 times
I'm with you all the way on the therapeutic qualities of wheel building. Built my rear wheel tonight courtesy of AdrianH and his rear hub.
Enjoyed watching this thread - it seems to be cracking on at a fair pace. Loving the in house garage shots.
Only had one free day to get in the workshop but made some progress
Rear guard fitted properly , footrests on , grab rail fitted , battery box fitted properly , front wheel and back wheel , tyres ,
I got a 2nd disc so need another caliper now ( more expense ) and opted for BT45 tyres
Sorted out all the engine parts so the head and barrels next
Sorry about the picture quality .....I lost the light and the fluorescents ruin the photos
- Attachments
- proj 74.JPG (55.91 KiB) Viewed 8880 times
- proj 73.JPG (92.35 KiB) Viewed 8880 times
- proj 72.JPG (98.56 KiB) Viewed 8880 times
- proj 71.JPG (83.69 KiB) Viewed 8880 times
Looking good Chris
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
My first attempt at clock restoration . I have gathered parts from all over the place and think I now have enough to put a set of Z1B together from this motley assortment
I have had some covers powder coated at Triple S and sourced some transfers from America ......now to sand down the old faces and apply the new ones ......this could end badly
- Attachments
- proj 79.JPG (81.46 KiB) Viewed 8824 times
- proj 78.JPG (118.9 KiB) Viewed 8824 times
- proj 77.JPG (95.04 KiB) Viewed 8824 times
- proj 76.JPG (85.71 KiB) Viewed 8824 times
- proj 75.JPG (67.9 KiB) Viewed 8824 times
well that wasn't too bad .....and they are translucent green numbers just like I was after
The little bit of white around the stop lamp will wipe off
- Attachments
- proj 80.JPG (94.38 KiB) Viewed 8818 times
Looking good!!!!!
Im liking that wheel building contraption, if you have the talent to rebuild your own rims, that could save both time and money.......
