Hi,
I was cleaning up the threads on the 12 engine studs from my Z400J project.
2 of the studs have a straight line "groove" in the threads, at the bottom end that goes into the crankcase.
I assume this isn't normal?
Will they need replacing, or is it ignorable?
Thanks for any advice.
Thread damage on stud - replace?
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
1982 Z400J project
ex owner of Z1100R
Re: Thread damage on stud - replace?
Looks like someone has put a saw cut across the threads to make them act as a thread cleaner or to true the threads in the alloy case.
Most likely the first 2 or 3 threads in the case were burred.
They are only on the threaded part and don't weaken the actual stud so i'd use them.
As long as the stud threads are not burred they should be fine to reuse.
That's good to know, thanks.
Also, ta to Zed1015 for the reason the marks are there- never knew of that.
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
1982 Z400J project
ex owner of Z1100R
I have a used standard set (bar one broken one) if you need some.
Big Fluff wrote:I have a used standard set (bar one broken one) if you need some.
That's very kind of you, if I get cold feet about using them I'll get back to you.
If you have other Z400J stuff do let me know- not too many owners out there!
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
1982 Z400J project
ex owner of Z1100R
