Oil c**k up
If the Magnatec is intended for use in cars it probably contains "friction modifiers" which can cause the wet clutch on a bike to slip, so even if the two oils are compatible you may still have problems.
As both products are made by Castrol you could drop them an e-mail and see what they think, but as others have said, you probably won't be happy until you've changed the oil.
Andy
Andy
Users browsing this forum: No registered users and 97 guests
