Wanted
r/h front hub dust cover off a KZ1000 single disc set-up, must be a few around has anyone got one they would be willing to part with.
KZ front hub dust cover WTD
Re: KZ front hub dust cover WTD
http://www.z-power.co.uk/dust-cover-front-wheel-right
Do you want the flat one or the domed one?
Thanks for the replies guys but I had one delivered from Z Power last week same as the two above but they are for fitting with a twin disc set-up, the right side one (as you sit on the bike) on the single disc set-up is a deeper cone shape to accommodate the additional distance to the hub that the second disc would fill on a uk bike. anyone who has converted a KZ single disc bike to twin disc should have the part I am after spare.
Think I may have one. Will have a look later on.
If you havent got one Adrian i have one,if its the rh one dished with two small mounting holes,pm me if interested.Paul j
Adrian / Paul
PMed you both thanks
This is what I have not Solid but not perfect, slight dent to side and where spindle goes through some distortion - this is on a 4 hole disc hub.
If the one Paul has is in better condition I'd go with his.
Thanks Paul it arrived yesterday very pleased.
