Starter Motor Harness
BigZCas
#1 PostAuthor: BigZCas » Fri Feb 16, 2018 8:03 am
Z1a
Good Morning,
Could someone advise if both the Stator Harness (Blue Plug) and the Starter motor harness should both run through the 2 hooks that are welded to the bottom of the Air box Support Plate (Stay-Air cleaner).
Or is just the one with the blue plug.
Thanks :??
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
BigZCas
Re: Starter Motor Harness
#2 PostAuthor: BigZCas » Fri Feb 16, 2018 7:08 pm
Does anyone know :?:
I can't fined any pictures :??
Past 5 Years
1976 KZ1000a1, Red
#3 PostAuthor: z1bman » Fri Feb 16, 2018 7:47 pm
they both route under the air cleaner bracket one clip secures the alternator harness the other is the starter lead
BigZCas
#4 PostAuthor: BigZCas » Fri Feb 16, 2018 8:32 pm
Great, thank you.
Past 5 Years
1976 KZ1000a1, Red
