Horn position a900a4. Help
glav666
#1 PostAuthor: glav666 » Sat Feb 24, 2018 10:07 am
Ok, sounds simple enough, but I've searched through pictures all over the web and I can't find any showing me the position of the horn on a UK z900a4. Can anybody on here enlighten me?
Know its up front and will only go where the wires stretch to but would like to be sure??
Re: Horn position a900a4. Help
#2 PostAuthor: Garry.L » Sat Feb 24, 2018 10:37 am
glav666 wrote:Ok, sounds simple enough, but I've searched through pictures all over the web and I can't find any showing me the position of the horn on a UK z900a4. Can anybody on here enlighten me?
If it's the same as the US model it's mounted on a small bracket behind the frame bracing below the headstock.
Not perfect pictures, but you can just see the horn, it's bracket and wiring just above the frame reflector in the second pic. The first shows the actual horn just below the headstock bracing.
8 Valve Mark
#3 PostAuthor: 8 Valve Mark » Sat Feb 24, 2018 11:48 am
if u need the original frame to horn brackets, gimme a shout m
glav666
#4 PostAuthor: glav666 » Sat Feb 24, 2018 1:35 pm
8 Valve Mark wrote:if u need the original frame to horn brackets, gimme a shout m
Thanks Mark, I have the brackets etc just couldn't remember where they went See my Avatar Dooh
glav666
#5 PostAuthor: glav666 » Sat Feb 24, 2018 1:36 pm
Thanks for that, its where I suspected :oops:
