Can someone tell me which route the rubber tank strap takes - I've snapped an OE one trying follow the exiting route which is round the frame tubes, even after heating it up - Gonzo came round this afternoon and his strap goes between the tubes on his Thou?
Andrew
Rubber tank strap route
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Re: Rubber tank strap route
there should be two small metal lugs under the frame tube which they hook on to
z1bman wrote:you can just make out one of the lugs on the frame tube
Interesting Jig
z1bman wrote:there should be two small metal lugs under the frame tube which they hook on to
Thanks, I'm ok with the lugs - it's the route the strap takes from there as in, does go round the tubes or between then - I don't want to keep snapping OE straps until I get it right.
Andrew
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Between them. They should be tight, if not it has stretched.
Mine fits round the outside of the tubes
When life hands you lemons, reach for the vodka.
Z1B (in Z1A colours), Z1000A1, ZRX1100 C4, Suzuki TS125J (being restored), Suzuki T125J (in boxes), Garelli Rekord MKII (awaiting restoration), most of a Garelli Rekord MKI
They fit around the outside of the tubes, you have stretch as you go.
Stretch to the first tube, stretch across the top to the other side then stretch to the second lug.
This way it will go on, JUST...
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
I stand corrected
