I have a couple of seized in air screws on my A4 carbs, is there a tried & tested way to get them out? I thought about penetrating oil, and maybe some heat but am not really sure how hot is safe. I know my carbs have muck in them so wanted to get them fully apart to clean all the passageways.
Carb Air Screws Seized - Any thoughts on how to get them free?
Re: Carb Air Screws Seized - Any thoughts on how to get them free?
hot air gun & plenty of penertrant
As in Painstripper Hot Air Gun & Plus Gas?
Sorry, am just a bit worried about getting it too hot...
Maybe soak them in carb cleaner and then give them a sharp tap, worked with a set of stuck pilot jets I had.
cancunia wrote:As in Painstripper Hot Air Gun & Plus Gas?
yes it will be fine
You may be lucky and they come loose with ultra-sonic cleaning!!
An ultrasonic cleaner might be handy for cleaning the carbs too, good idea. Any thoughts on a good make / model to look out for? I did a search and see loads of results about carb cleaning, just wondered if there are any favourite cleaners to check out.
I just bought a ‘gt sonic newest’ 6litre Chinese one off amazon. Looks like a little chip fryer, its the one with3 rotary knobs on it.
It's actually quite well made and has just cleaned up a set of z1000a carbs a treat. At 6litre size you need to break the set down and do one body at a time.
Obviously I can’t say how long it’ll last as I’ve only run it four times but so far I’m quite impressed. £170 i think.
Olly
Olly
Lemmy
Lemmy
