Z1a Chain Oiler Pump
BigZCas
#1 PostAuthor: BigZCas » Tue Apr 17, 2018 8:39 am
Can anyone advise what the O Ring (92055053) is for that fits onto the pump drive shaft ?
Do I still require the O Ring if I am not actually running oil through ?
Is it OK to run the chain oiler pump without chain oil ?
Thanks for any advice.
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
cancunia
Re: Z1a Chain Oiler Pump
#2 PostAuthor: cancunia » Tue Apr 17, 2018 9:01 am
The oil in the pump probably helps to lube the pump itself, so I'd say don't run it without oil. I've never worked out why my A4 came without the pump but it seems ok without it, just need to lube the chain directly.
#3 PostAuthor: ZedHead » Tue Apr 17, 2018 2:23 pm
BigZCas wrote:Can anyone advise what the O Ring (92055053) is for that fits onto the pump drive shaft ?
Some sort of rubber protection, like a condom :oops:
#4 PostAuthor: PAULJAC47 » Tue Apr 17, 2018 2:38 pm
cancunia wrote:The oil in the pump probably helps to lube the pump itself, so I'd say don't run it without oil. I've never worked out why my A4 came without the pump but it seems ok without it, just need to lube the chain directly.
z1A was the last to have a chain pump,a4 always never had one...
BigZCas
#5 PostAuthor: BigZCas » Tue Apr 17, 2018 7:10 pm
Anyone got one of these special O Rings they could spare ?
Really don't want to pay £15 shipping for a €4 part :(
Past 5 Years
1976 KZ1000a1, Red
hal
#6 PostAuthor: hal » Tue Apr 17, 2018 7:48 pm
You could just measure it up then look on ebay.
