I've recently stripped my carbs to clean them, and noted that the needle jets (5J9) are set at position 4, where the manual says position 3 (for a 73 bike)
What will be the difference with the two positions (richer or lean) and at what part of the rev range/throttle opening ?
I also note the new main jets that came in the carb kits are 113, the originals fitted are 112.5 - again, what can I expect from the difference ?
.....and if anyone has any recommended settings that deviate from factory - please advise
Bike is standard with standard airfilter and airbox/exhaust etc
Z1 carbs help
Z1 carbs help
73 Z1
80 Moriwaki Monster
80 Moriwaki Monster
Re: Z1 carbs help
Does it run ok?
- warren3200gt
Re: Z1 carbs help
The higher the needle, ie the lower the clip, richens high revs. The lower the needle, ie the higher the clip, weakens/leans the high rev range.
Where it needs to be depends on exact exhaust you have and exact air filter, and fuel quality.
As Chris says, if it runs ok leave well alone.
Re: Z1 carbs help
Not run it yet, as it had been standing sometime
Needed to rebuild front caliper as it was sticking and strip carbs as they were pretty crusty
My observations were during the strip
The information provided is certainly useful, but agreed will have a better idea when I give it a good run
I was hoping to get them ‘right’ first time but guess thats pretty rare !
73 Z1
80 Moriwaki Monster
80 Moriwaki Monster
- warren3200gt
Re: Z1 carbs help
Question is then, was it running ok before it was left standing?
Re: Z1 carbs help
warren3200gt wrote:Question is then, was it running ok before it was left standing?
Not really, as its not really been used for the past 3 years - so poor fuel would also factor in
I did speak to the previous owner that claimed it was a bit rough when cold, but then settled down when warm
If the opinion that the factory settings are as good as it gets, then I'll revert
Was hoping that someone had experience and could advise if my deviation of using 113 mains and the needle jet one position different is enough of a change to affect the running considerably
73 Z1
80 Moriwaki Monster
80 Moriwaki Monster
