Alternator wiring loom
hal
#1 PostAuthor: hal » Thu May 10, 2018 10:42 am
Going to replace the alternator wiring loom and grommet with a new one from Z power, but I am a bit confused about the connections at the alternator the original wires are pink yellow and blue but the new ones are all yellow. Does this mean it doesn't matter which yellow wire wire goes where ?
Julian_Boolean
Re: Alternator wiring loom
#2 PostAuthor: Julian_Boolean » Thu May 10, 2018 10:46 am
Yes
#3 PostAuthor: ZedHead » Thu May 10, 2018 10:47 am
Hal, it doesn't matter. They are just different phases. Your rectifier or combined reg/rec will sort it out.
hal
#4 PostAuthor: hal » Thu May 10, 2018 10:51 am
Thanks for the quick response guys I can get on with It now.
