Fuel Tank - Sealant or Not?
bulldogbobby
#1 PostAuthor: bulldogbobby » Wed May 23, 2018 4:27 pm
About to install a replacement fuel gauge sensor to my Z1R tank. Is it worth using sealant with the gasket and if so, what's the best stuff to use?
Cheers!
Re: Fuel Tank - Sealant or Not?
#2 PostAuthor: z1bman » Wed May 23, 2018 5:57 pm
no the seal should be enough
bulldogbobby
#3 PostAuthor: bulldogbobby » Thu May 24, 2018 8:58 am
z1bman wrote:no the seal should be enough
Cheers mate - I'll fit the sensor then fill the tank with fuel and leave it off the bike to check for leaks before i put it back on :up
