Diamond Brown - Rattle Can ?
cancunia
#1 PostAuthor: cancunia » Fri May 25, 2018 9:56 am
I need to touch up a couple of paint chips and wondered if anyone has found a close rattle can match for Diamond Brown (or is that Diamond Red)?
Taffus
Re: Diamond Brown - Rattle Can ?
#2 PostAuthor: Taffus » Fri May 25, 2018 12:53 pm
Think its "ditch Pump Brown" :D
Blackseven
#3 PostAuthor: Blackseven » Fri May 25, 2018 7:36 pm
Just take a panel to a good auto paint shop and let them paint match it for you and make up either a pot of touch up or make up an aerosol. Its not expensive and decent independent auto paint specialists can mix up a match which takes account of the way that your original paint has faded over time. I've had loads done over the years for lots of old cars and bikes and the match is usually perfect or as close as makes no difference. Rob
