Break Calipers
Break Calipers
Hi Guys Just trying to find out what these calipers fit had them a long while but carnt remember what the came off any idea welcome ????
Z1B Happy Days Get the Z out and go for a Blast
Re: Break Calipers
With a pair of em more likely Z650c models unless one of the above has been converted.
Re: Break Calipers
Hi Guys thanks for the info I just brought them as you see them so dont know if they have been messed with so still not sure what they are off
Thanks any way Mark
Thanks any way Mark
Re: Break Calipers
Measure the distance of the mounting holes as they would determine if they are early z or z900a. As they changed after that time
Re: Break Calipers
Charlie wrote:With a pair of em more likely Z650c models unless one of the above has been converted.
+1
Re: Break Calipers
They are Z or Kh callipers from 1976 onwards. Totally different to Z1 calipers. What they are off depends on piston size.
Re: Break Calipers
Hi Guys The hole mounting centers are aprox 72 mm
