Does anyone know if there has ever been a hydraulic clutch kit made for the Z650?
CB is struggling with hers now and I am considering making a hydraulic clutch actuator for her, but it would be great if there was a tried and tested system out there to make my life easier; either yo copy or better still buy!
Z650 Hydraulic Clutch?
- RALPHARAMA
Ralph Ferrand
- warren3200gt
Re: Z650 Hydraulic Clutch?
Not sure about a hydralic clutch but im pretty sure the twin worm drive unit for the h1, 2 & kh's is an easy conversion. Making the clutch twice as light. Just dont know if its still available anywhere? Sure someone on the triples club forum would be able to give you details.
- RALPHARAMA
Many thanks for that. I'm a member of the triples forum so I have posted the question.
Given her astonishing ability to break clutch cables on whatever bike she rides, I like the idea of a hydraulic clutch, the the triple version sounds a lot easier and hopefully cheaper
Ralph Ferrand
This one is on Guyzeds bike, not sure if he is still on hte site, there was a german company offering a kit. Think they have stopped making them, so it would have to be like Guys and DIY. All you need is a clutch handlebar master cyl that matches your rh brake and a suitable slave cyclinder that can be fixed into a mounting that will be welded into the cover.
the guys name is Falk Stumm, he is on Facebook
https://www.facebook.com/falk.stumm
I like that. That is a conversion I would like to do too
- RALPHARAMA
I have bought another final drive case to attack! I have also ordered a 900R master cylinder and slave. I doubt the slave will be suitable but it will give me a piston diameter to work from and a piston in the unlikely event it's not fucked! Watch this space
Ralph Ferrand
- warren3200gt
https://www.amazon.co.uk/CLUTCH-HYDRAUL ... B00PCE2LWY
Google magura hymec, available from several places, venhill has a decent pdf on them. They have several actuator lengths available.
Julian_Boolean
warren3200gt wrote:https://www.amazon.co.uk/CLUTCH-HYDRAULIC-MAGURA-HYMEC-167-877197/dp/B00PCE2LWY
I've got one of those off a Yamaha WR400 knocking round in the garage, it has a bent lever, I should really put some effort into fitting it to my Z1170.
