Z900/1000 etc RH switchgear or just lightswitch & lever
Big Fluff
#1 PostAuthor: Big Fluff » Sun Jun 17, 2018 3:33 pm
As per heading, I'm after the RH switchgear please for a Z1R.
Failing that just the actual lightswitch & lever and I'll have to run the extra wiring in.
This is for a Californian import that has no switch (lights on constantly) and the customer wants to have the UK spec.
Thanks, Will
8 Valve Mark
Re: Z900/1000 etc RH switchgear or just lightswitch & lever
#2 PostAuthor: 8 Valve Mark » Sun Jun 17, 2018 7:59 pm
i think the gubbins from ke, kh n small z models should be suitable and hopefully ease your search/increase your chances too. good luck. mark
Big Fluff
#3 PostAuthor: Big Fluff » Sun Jun 17, 2018 9:10 pm
Thanks, good tip.
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Sun Jun 17, 2018 9:38 pm
happy to help mate, your customer might want a left hand switch too which has the hi-beam, flash facility. same rules apply.. cheers mark
