Z1000R Helmet & Seat Lock
MikeP
#1 PostAuthor: MikeP » Sat Aug 11, 2018 7:24 pm
I've just changed the ignition lock on my '83 Z1000R, which was pretty straight forward, but now leaves me with 3 keys - one for the ignition, one for the seat lock and one for the helmet lock.
Does anyone on here know how to remove the barrels from this style of lock or know someone who can at least reduce the helmet and seat lock into one key?
Re: Z1000R Helmet & Seat Lock
#2 PostAuthor: Philippe » Sun Aug 12, 2018 4:36 am
Hi Mike
can you put some pictures of those locks on the forum? Maybe I can tell you how to remove the barrels and change the inside of it to one key.
I'm doing the same thing at the moment for a KZ1000P.
The most difficult part of the job is to get the barrels out without rendering them unusable...
pertonpc
#3 PostAuthor: pertonpc » Sun Aug 12, 2018 9:58 am
If it is anything like ZRX 1200 helmet lock it is fairly easy to do.
Will try and find the link on how to do it.
Helmet lock was basically take it to bits - do it in a clean area as there are some tiny springs that push the brass wafers into place.
There is one large brass wafer which holds the barrel into the lock body - does not affect the key.
Then there are 3-4 small brass wafers that slot into 5 slots on the barrel body (at least one slot will be empty).
It is just a case of swapping the 4 wafers around until you get them right for your key ( they fit flush to barrel when key is inserted).
If you are lucky you can jiggle them round and re-use all 4 wafers - if not it will work fine with just 3 wafers fitted.
If you want to get really tech you could probs adjust the slot on a wafer with mini file etc. but I did it by swapping them round.
Once you are happy barrel spins in body with wafers and key inserted - re-assemble in reverse order.
Ok found it - you need to read down this thread for a while and you get to all the pics on how it works -
http://www.zrxoa.org/forums/showthread. ... ded-Please
From Mark
MikeP
#4 PostAuthor: MikeP » Sun Aug 12, 2018 10:07 am
Good morning Philippe,
here's a few shots of the two locks:
Thanks, Mike
MikeP
#5 PostAuthor: MikeP » Sun Aug 12, 2018 10:36 am
pertonpc wrote:If it is anything like ZRX 1200 helmet lock it is fairly easy to do.
From Mark
Thanks for the help and the link but these barrels seem to be slightly harder to remove from the lock body. As can be seen from the addition foto the barrel is stopped from sliding forward by, what looks like, a wafer lock (slightly obscured brass coloured in the foto) and this also controls the quarter turn of the key but there is no way to remove the offending wafer.
As there's no evident pin on the outer holder to retain the barrel I'm thinking I have to remove the chrome key plate, which might hide the securing method. Unfortunately if not I'll then be wrecking the lock appearance :(
MikeP
#6 PostAuthor: MikeP » Sun Aug 12, 2018 3:55 pm
Mark,
apologies for not fully grasping what the link you kindly sent said - I wasn't a ZRX forum member and hence couldn't see some of the important images earlier. Now I'm a full ZRX member I can see the images and see that I have to press the gold wafer into the barrel and hey presto the barrel drops out - oops bad choice of words.
Thanks again for your help
pertonpc
#7 PostAuthor: pertonpc » Sun Aug 12, 2018 7:02 pm
Here is my ZRX helmet lock dismantled - note the larger retaining wafer on right & the 6 slots you can choose from to make key fit.
Got to get the wafers into a place where the whole lot is flush when key goes in - like this - then test it in the barrel to make sure before reassembly.
Note the position of the larger retainer wafer - no effect on key action.
You can see the 2 slots which I did not use - and where the 4 ended up.
New part was different appearance & key style altogether so would not have matched up too good.
Hope you are sorted now ??
MikeP
#8 PostAuthor: MikeP » Sun Aug 12, 2018 7:41 pm
Yes thanks Mark, all sorted on 2 keys. It was the rear view that sorted it (ooow eeeer missus) with the red grease showing the same brass locking wafer. Just needed a blade to compress the little blighter and out popped the barrel.
I had some spare wafers from an old ignition switch that could be filed. I've got an old helmet lock that, now I know how to release the barrel, I can make to suit the Z5488 key I have leftover.
Thanks again Mark :up
#9 PostAuthor: Philippe » Mon Aug 13, 2018 3:31 am
Hi Mike
just noticed that you allready got help from Mark! That's why there's a forum. We help eachother!
The other lock might be more difficult but the basics are the same. The hardest part is to get the barrel out.
Unscrew the back plate and find the retaining part to get the barrel out. Afterwards it's the same as the other lock.
I have no experience with the lock on the picture . Maybe someone else has...
Good luck
MikeP
#10 PostAuthor: MikeP » Mon Aug 13, 2018 9:05 am
Thanks Philippe, fortunately I set the helmet lock to the seat lock key so didn't have to investigate further, as the locking wafer wasn't easily accessible.
Cheers, Mike
#11 PostAuthor: Philippe » Mon Aug 13, 2018 2:32 pm
Hi Mike
thanks for the update!
#12 PostAuthor: chrisNI » Mon Aug 13, 2018 6:36 pm
Anyone got one of those 1000R helmet locks surplus to requirements and they’d care to part with :D
MikeP
#13 PostAuthor: MikeP » Mon Aug 13, 2018 6:55 pm
chrisNI wrote:Anyone got one of those 1000R helmet locks surplus to requirements and they’d care to part with :D
I might have a spare, with a kwaki key, that I'd part with. I bought the new one photographed as I didn't know how to change the wafers.
I'll put a few fotos up if you're interested?
#14 PostAuthor: chrisNI » Mon Aug 13, 2018 10:40 pm
PM sent
MikeP
#15 PostAuthor: MikeP » Tue Aug 14, 2018 4:59 pm
Here's a few extra piccies of the spare helmet lock
Users browsing this forum: No registered users and 85 guests
