spark plug query
dave cullen
spark plug query
#1 PostAuthor: dave cullen » Sat Sep 01, 2018 6:37 pm
If you find your bike is fouling up a wee bit after prolonged low speed running in town or traffic and you don't do a lot of high speed stuff, would it be worth dropping down a grade of plug, eg B8ES to B7ES??
Z900A4 Z1000A1
Charlie
Re: spark plug query
#2 PostAuthor: Charlie » Sat Sep 01, 2018 6:50 pm
It should not be fouling up. You might want to check your fueling and carb settings
compo z1r
#3 PostAuthor: compo z1r » Sat Sep 01, 2018 7:22 pm
dave cullen wrote:If you find your bike is fouling up a wee bit after prolonged low speed running in town or traffic and you don't do a lot of high speed stuff, would it be worth dropping down a grade of plug, eg B8ES to B7ES??
take Charlie's sound advice or u may well as drop down from semi synthetic to fry crisp and dry and from super 97 to 2 star :shock:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
dave cullen
#4 PostAuthor: dave cullen » Sat Sep 01, 2018 8:55 pm
yeh,
This is all a bit odd, as I have posted before re my ELR, I got a refurbed set of carbs from Wired George in the states, the bike is running brilliantly on the motorway, and A roads, and it had a good dyno run, but it just does not like getting stuck in traffic, and it's fouling up, I AM running it on super unleaded to try and stave off ethanol storage problems, maybe I should go back to regular unleaded for a bit?
I really don't want to have more workshop time, so I can put up with it, was just a thought re the plugs
Dave
Z900A4 Z1000A1
compo z1r
#5 PostAuthor: compo z1r » Sat Sep 01, 2018 9:04 pm
dave cullen wrote:yeh,
Dave
dave what u running pods or standard air box ?
#6 PostAuthor: zed1015 » Sat Sep 01, 2018 9:50 pm
Over fueling on the low end.
Try weakening the mix slightly with the air screws.
dave cullen
#7 PostAuthor: dave cullen » Sun Sep 02, 2018 8:16 am
standard air box,
Z900A4 Z1000A1
dave cullen
#8 PostAuthor: dave cullen » Sun Sep 02, 2018 8:17 am
zed1015 wrote:Over fueling on the low end.
thanks, will do some tweaking in due course
Z900A4 Z1000A1
compo z1r
#9 PostAuthor: compo z1r » Sun Sep 02, 2018 9:37 am
rob's correct but one of the things ive done in the past is use a less restrictive filter k&n or better and drilled the air box then set up with a colour tune had it spot on ? but not on a elr box :D
#10 PostAuthor: ZedHead » Sun Sep 02, 2018 12:20 pm
Spark Plugs for Classic Engines.pdf
(57.5 KiB) Downloaded 199 times
Yes!
This is the advice from NGK... read attached
#11 PostAuthor: warren3200gt » Sun Sep 02, 2018 12:49 pm
7's are hotter than 8's. They run better at lower speeds. KHI changed from 8 to 7 after the first year on 650's.
dave cullen
#12 PostAuthor: dave cullen » Sun Sep 02, 2018 5:41 pm
I think i am going to try dropping the plugs to B7's, i got a dyno print out for new carbs and it was great i am told. When i was on run friday, it ran great but previously i got stuck in a big jam and it fouled up. Will report back thanks guys
Z900A4 Z1000A1
King of Kings
#13 PostAuthor: King of Kings » Mon Sep 03, 2018 11:48 pm
Possibly try a set of Brisk plugs, though nowt wrong with dropping to B7s, as per the workshop manual :)
Big Fluff
#14 PostAuthor: Big Fluff » Tue Sep 04, 2018 3:50 pm
Sounds like it's running too advanced ignition... i.e retard not functioning etc.
