spark plug query
				dave cullen
spark plug query
If you find your bike is fouling up a wee bit after prolonged low speed running in town or traffic and you don't do a lot of high speed stuff, would it be worth dropping down a grade of plug, eg B8ES to B7ES??
									Z900A4 Z1000A1
						Re: spark plug query
It should not be fouling up. You might want to check your fueling and carb settings
dave cullen wrote:If you find your bike is fouling up a wee bit after prolonged low speed running in town or traffic and you don't do a lot of high speed stuff, would it be worth dropping down a grade of plug, eg B8ES to B7ES??
take Charlie's sound advice or u may well as drop down from semi synthetic to fry crisp and dry and from super 97 to 2 star
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
				dave cullen
yeh,
This is all a bit odd, as I have posted before re my ELR, I got a refurbed set of carbs from Wired George in the states, the bike is running brilliantly on the motorway, and A roads, and it had a good dyno run, but it just does not like getting stuck in traffic, and it's fouling up, I AM running it on super unleaded to try and stave off ethanol storage problems, maybe I should go back to regular unleaded for a bit?
I really don't want to have more workshop time, so I can put up with it, was just a thought re the plugs
Dave
Dave
Z900A4 Z1000A1
dave cullen wrote:yeh,
Dave
dave what u running pods or standard air box ?
Over fueling on the low end.
Try weakening the mix slightly with the air screws.
				dave cullen
				dave cullen
zed1015 wrote:Over fueling on the low end.
thanks, will do some tweaking in due course
Z900A4 Z1000A1
dave cullen wrote:zed1015 wrote:Over fueling on the low end.
rob's correct but one of the things ive done in the past is use a less restrictive filter k&n or better and drilled the air box then set up with a colour tune had it spot on ? but not on a elr box
Yes!
This is the advice from NGK... read attached
- warren3200gt
7's are hotter than 8's.  They run better at lower speeds. KHI changed from 8 to 7 after the first year on 650's.
				dave cullen
I think i am going to try dropping the plugs to B7's, i got a dyno print out for new carbs and it was great i am told. When i was on run friday, it ran great but previously i got stuck in a big jam and it fouled up. Will report back thanks guys
									Z900A4 Z1000A1
				King of Kings
Possibly try a set of Brisk plugs, though nowt wrong with dropping to B7s, as per the workshop manual
Sounds like it's running too advanced ignition... i.e retard not functioning etc.
