Spark Plug Cap
AlanB
Spark Plug Cap
#1 PostAuthor: AlanB » Wed Sep 19, 2018 7:12 pm
Think I need to replace a cap on my 79 Z1000 A2 so will do all 4 I think - If I replace like for like with NGK caps, which ones do I need and are the inner/outer ones the same ? Also are there any tips on fitting ie do you simply unscrew the old and screw on the new ones ? Thanks all. :roll:
Re: Spark Plug Cap
#2 PostAuthor: z1bman » Wed Sep 19, 2018 7:31 pm
AlanB
Re: Spark Plug Cap
#3 PostAuthor: AlanB » Wed Sep 19, 2018 8:02 pm
Thanks - These state resistor type - Are they ok with non resistor NGK B8ES plugs ?
Re: Spark Plug Cap
#4 PostAuthor: z1bman » Wed Sep 19, 2018 8:19 pm
should be the original Kawasaki plug cap had a resister
Re: Spark Plug Cap
#5 PostAuthor: warren3200gt » Thu Sep 20, 2018 2:57 am
You need either no resistor on cap and plug or either one to have a resistor but not both.
Re: Spark Plug Cap
#6 PostAuthor: PAULJAC47 » Thu Sep 20, 2018 8:02 am
If you are replacing the plugs be certain to get genuine Ngk loads of copies out there,Denso are a better bet...
snowyz9
Re: Spark Plug Cap
#7 PostAuthor: snowyz9 » Thu Sep 20, 2018 4:11 pm
Warren never heard of resistor on one or other before , but must admit ngkb8es used to go down a lot on startup on my old z900 , one wet , useless , wonder if that was the prob , But it sounds like the combination spoke of here is wrong
Re: Spark Plug Cap
#8 PostAuthor: warren3200gt » Thu Sep 20, 2018 4:25 pm
Not sure why we bother with any resistors, either plugs or caps, these days. As far as I cant tell, the only reason to run resistors anywhere in that circuit is so it doesn't interfer with the old analog tv signals. As they are all digital now I dont see any benifit. I prefer the look of ngk non resistor black caps and run non resistor denso plugs. No resistors at all means one thing less to go wrong!
snowyz9
Re: Spark Plug Cap
#9 PostAuthor: snowyz9 » Thu Sep 20, 2018 4:29 pm
Lol , luckily , i bought up a few of them black cap Ngk non resistor ones a while ago
Users browsing this forum: No registered users and 102 guests
