Can someone advise me as to the type of tap that should be fitted to the petrol tank on a early (october 1975) US import Z900A4? The tank that came with the bike is the two m6 bolt flange type, I also have a spigot type tank, which I guess it should have. Hoping someone will clarify for me.
Cheers, Mick
Z900 A4 fuel tap
Re: Z900 A4 fuel tap
Here you go:
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
2 bolt flange type tap is off a 1978 Z1000A2
ADRIAN H wrote:2 bolt flange type tap is off a 1978 Z1000A2
What he said. A2 is a Vac tap.
Thanks guys. It's as I thought. At least I won't fit the wrong tank now. Cheers Mick
