Carburettor Help
Re: Carburettor Help
#16 PostAuthor: ZedHead » Tue Oct 02, 2018 9:45 pm
ZedHead wrote:
Philippe wrote:Hi Arctic fox
based upon the pictures I would say it's the third carb and it's a Mikuni VM28SS. The black rubber shouldn't be on the copper tube. The copper tube is connected by a rubber hose to the vacuum fuel tap.
You have to look for a number embossed in the carb slide. If you found that number you can identify the type of bike it was on originally. My guess: a Z1000ST or Z1000MK2, the carbs are very similar, only the main jets are different.
Good luck
Makes sense for these to be 1979/8 carbs which went back to Air screws instead of the under bowl pilot screws
I agree the rubber plug should not be there, although I think the nozzle are breather vents. Does the fuel tap vacuum pipe not come off one of the vaccum gauge take offs?
Is there a cross reference somewhere for the slide numbers?
#17 PostAuthor: Philippe » Wed Oct 03, 2018 5:55 am
Hi guys
@ arctic fox: sorry I can't help you with the jetting. As I wrote: I allways mount them to standard specs and have no experience in adapting those. I'm sure there are some guys on the forum who can help you out.
@ zedhead: in the case of VM28SS carbs the fuel tap vacuum pipe doesn't come from the rubber intake nozzle. It comes from the nozzle of the third carb. Take a look at that carb: the nozzle exits in the bore towards the intake rubber . When the engine is running the suction creates a vacuum, opening the diafraghm in the fuel tap allowing fuel to run to the carbs.
I don't know if there's a cross reference for the slide numbers, I try to determine what carbs I have and then check the details in the technical workshop manuals in order to be sure.
#18 PostAuthor: ZedHead » Wed Oct 03, 2018 3:46 pm
Thanks Phillipe,
It is hard to tell where the nozzle exits from the picture. There appears to be galleries going to the bowl breather?
I have figured the throttle valve numbers are just the cut off height. Which is shown in the parts manuals to assist in identification.
I am pretty convinved that Neils carbs are non-US MKII
#19 PostAuthor: Philippe » Fri Oct 05, 2018 8:23 am
Hi Zeadhead
the only difference between MK2 and ST carbs is the size of the main jet. MK2 has a 105 main jet, the ST has a 110 main jet. You can mount the same carbs on both of the bikes, 0,05 mm doesn't make a big difference.
#20 PostAuthor: ZedHead » Fri Oct 05, 2018 11:17 am
Philippe wrote:Hi Zeadhead
Thanks for sharing your expert information on this. Just one addition from me. Mikuni jet numbers are the flow rate in cc's per minute when poured from a height of 50cm's. The attached gives details one persons research on the numbers.
mikuni.pdf
(11.03 KiB) Downloaded 134 times
Arctic Fox
#21 PostAuthor: Arctic Fox » Fri Oct 05, 2018 4:17 pm
Inspected the carbs, those nozzles go to the top of the fuel bowls, so are indeed breathers.
1975 Z900 A4
#22 PostAuthor: Philippe » Sat Oct 06, 2018 4:21 am
Hi Zedhead
thank you for the explanation! JC I didn't know that!!! I assumed it was the diameter in hundreds of mm that was stamped on the main jet. Now I know how little I know. Thanks again Sir.
