Z1000A1 REAR CALIPER
Guyz ,Looking for some dimensions if anyone has a z thou a1 or a2 caliper in bits,need piston dimensions diameter and length,gap between piston bores when pistons fully back,.....got a rotor here 7mm,new pads are 9mm apiece,disc rotor is dead central,thinking may have mismatch of bits,reckon would need to lose 3mm at the mo so brakes wouldnt bind..Ta Paul J
Re: Z1000A1 REAR CALIPER
Have one in the garage, I am working away and won’t be home till late Saturday but can have a look Saturday evening or Sunday - if no one else can help out before then.
Thanks Adrian
Diameter 42.74mm
Depth 22.75mm
Distance between retracted pistons 22.6mm
Depth 22.75mm
Thats Great Adrian,explains why my set up is binding,my rotor is 7mm,new pads are supplied as 9mm or 8mm a piece plus 1mm for the anti rattle shims,that makes 7+8+8+1=24 at the best some pads are 7+9+9+1=26,both way over 22.6 as you state,whats the thickness of your rotor? are your pads thinner than 8mm?..Many Thanks Paul J
The disc is 7mm will check the pads pretty sure I couldn’t use the anti rattle shims and had to file down the pads to get them to fit.
Will check pad thickness tomorrow.
