Hello,
the Z1000a I'm rebuilding has been fitted with a big bore kit so that the bore is now around 74mm. Is there a big bore head gasket available which will fit this?
Cheers, MikeJ
Z1000a Big bore head gasket
Too much is never enough
Re: Z1000a Big bore head gasket
Hi Mike
look at these:
http://z-fever.de/shop/product_info.php ... 35ccm.html
https://www.scheuerlein-motorentechnik. ... 1000a.html
I'm sure you can allso buy them in the UK but I don't know where.I think someone else can help you out
look at these:
Hello Phillipe,
many thanks for the reply and I'll check them out,
Cheers, MikeJ
Cheers, MikeJ
Either Debbens (01425 474628) or SPS http://www.suzukiperformancespares.co.u ... askets/64/ should be able to help with either an MLS or copper head gasket for youre size bore depending on what you want.
If it's a basic normally aspirated motor you want a Cometic cfm20 graphite fibre gasket.
Nick at Suzuki Performance spares can supply this one which suits 1075cc (72mm ) to 1135cc (74mm) bore.
http://www.suzukiperformancespares.co.u ... sket/1254/
Don't bother with copper unless you are racing and the MLS need a very clean and flat surface to seal which you will unlikely have unless the block and head have been resurfaced.
