Z900 a4 cylinder head
gaz
#1 PostAuthor: gaz » Mon Nov 19, 2018 4:06 pm
Has anyone got a good cylinder head for a z900 a4 76-77 for sale
Re: Z900 a4 cylinder head
#2 PostAuthor: Ultim8pc » Mon Nov 19, 2018 4:09 pm
I've got one, it's been welded, but doesn't affect operation. You can have it for £50 if it's any use.
gaz
#3 PostAuthor: gaz » Tue Nov 20, 2018 10:51 pm
Sounds good where has it been welded thanks
#4 PostAuthor: Ultim8pc » Tue Nov 20, 2018 10:53 pm
gaz wrote:Sounds good where has it been welded thanks
On the rear, not sure why it has been welded as was like that when I got it. I'll see if I can take some photos.
BTW - Has no cam caps, but I mght be able to rustle up a matching set if needed..
gaz
#5 PostAuthor: gaz » Tue Nov 20, 2018 10:59 pm
Sounds ok can you send some photos thanks
gaz
#6 PostAuthor: gaz » Wed Nov 21, 2018 11:43 pm
Hi don't want to push you the set of cam caps will help me out some photos will help me to thanks gaz
#7 PostAuthor: Ultim8pc » Thu Nov 22, 2018 11:22 am
Sorry, been somewhat busy, will try to dig the head out.
gaz
#8 PostAuthor: gaz » Thu Nov 22, 2018 12:41 pm
Thanks it's much appreciated
