Hello . I need to repair a lock stop on a spare Z1 bottom yoke
What material are they made of and best welding method please
Yoke material
Re: Yoke material
I think they are cast iron, and the best way is muggy welding, which most don't do.
Re: Yoke material
They are cast STEEL.
You can weld via Gas, Mig. Tig or Arc.
Probably best to use ARC in short bursts to build up a new stop.
Re: Yoke material
Thanks ......I will look at it over xmas
Re: Yoke material
If using arc on a cast steel opt for a hydrogen controlled electrode
Less chance of cracking occurring in the heat affected zone
Z1000 MK2
Z1300 DFI
Z1300 DFI
Re: Yoke material
I stand corrected, cast steel it is then, should be easy to build the repair up.
