Centre stand
Adrian90s
Centre stand
#1 PostAuthor: Adrian90s » Sat Dec 22, 2018 1:08 pm
Hi guys,
Is it practical/possible to lower the centre stand by lifting the back end with a person either side and one of us kicking the centre stand down
The front end is clamped on a lowered ramp and an exhaust is not fitted.
Thanks guys and merry Christmas
gpjes
Re: Centre stand
#2 PostAuthor: gpjes » Sat Dec 22, 2018 1:29 pm
Haha, Motorcycle World days, Bradford, z1300 six of us, so to your question, yes, but only if your mates are stood on summat but also make sure as hell that front wheel besides being clamped is strapped so it can't come out, and put a tiewrap on front brake lever to lock front wheel, overkill is always the best way, coz if you don't, shit will always happen, an easier way though is to invest in the fancy bench lift which goes under front frame rails, then you can do it yourself :D have a good one :idea
More Smiles Per Mile
Re: Centre stand
#3 PostAuthor: Philippe » Sat Dec 22, 2018 5:13 pm
Hi Adrian
how the F*** did you get in such a situation? Make sure there's enough guys to support the bike when lifting it.
Hope you succeed! Merry X-mas!
Adrian90s
Re: Centre stand
#4 PostAuthor: Adrian90s » Sat Dec 22, 2018 5:27 pm
Hi Phillipe,
Its a short bike ramp, and I cannot run it forward enough to set it back on the centre stand. I have the front wheel firmly clamped and straps to keep it upright..took 2 people to steady the ship.
I do have a small lift but I doubt if it will go on the existing ramp.
gpjes
Re: Centre stand
#5 PostAuthor: gpjes » Sun Dec 23, 2018 7:27 am
Stick a piccie of bike lift on, give us a better idea/amusement :D
Adrian90s
Re: Centre stand
#6 PostAuthor: Adrian90s » Sun Dec 23, 2018 10:46 am
Er..it's a bike on a ramp with straps on it and the front wheel clamped...much like a roadside recovery vehicle.
Will try and see if the small ramp fits underneath
Adrian90s
Re: Centre stand
#7 PostAuthor: Adrian90s » Sun Dec 23, 2018 12:04 pm
Problem solved, got it on the centre stand on my own.
Small ramp onto my bigger ramp then jacked the back end up.
All good!!
Re: Centre stand
#8 PostAuthor: Philippe » Sun Dec 23, 2018 2:02 pm
Hi Adrian
good to read that you succeded, nothing as clever as a man but he has to think to find a solution!
Good luck
Adrian90s
Re: Centre stand
#9 PostAuthor: Adrian90s » Sun Dec 23, 2018 3:29 pm
Thanks Phillipe,
Begin to strip the back end off after new year,
Wheel off and restore, wrong rim on (No markings) and from paint to repair, swinging arm off and powdercoat.
Ady
gpjes
Re: Centre stand
#10 PostAuthor: gpjes » Mon Dec 24, 2018 8:09 am
Nice one, my knees are knackered kneeling down to fix stuff throughout my life, not any more though working at a decent height it's great on bench :D
nicomkii
Re: Centre stand
#11 PostAuthor: nicomkii » Mon Dec 24, 2018 10:04 pm
I'm lucky enough to have a cross beam in the shed so I can use a pulley to lift the rear end up.
Nico
8 Valve Mark
Re: Centre stand
#12 PostAuthor: 8 Valve Mark » Tue Dec 25, 2018 4:00 am
nicomkii wrote:I'm lucky enough to have a cross beam in the shed so I can use a pulley to lift the rear end up.
enough about you n the mrs nico!! this is a family forum up here! brrr :sad
merry Christmas tho!! mark x
