Does any one have a std set of rear shocks for a st ? I don’t mind the condition as I would try to get them re conditioned
Thanks mark
Shaft drive
Shaft drive
Re: Shaft drive
Hi Mark
the problem with the original rear shocks is that they 're all 38 or 39 years old...the chrome is rusted or damaged and the oil has gone or the springs became rusty...
It's possible to disassemble them and to repaint them but you need undamaged chrome on the steel inner tube.
If the chrome is damaged, buy new ones. I use hagon shocks, you can buy them with chromed or black painted springs and for normal use they perform good. Sometimes one has to make a compromise as far as originality is concerned...I prefer safety to originality.
Re: Shaft drive
Progressive suspension do shocks with the top shroud which look a little more like the origionals. They are a very good shock.
Re: Shaft drive
Thanks .i have konis on there which look very similar I was trying to keep it original as it’s only done 20000 miles with every thing else including paint work and pipes still in a really good condition I have only changed the handle bars to higher ones for personal preference
Re: Shaft drive
Hi Mark
keep the KONI shocks on your ST ! These are far better than the original ones.
- paul doran
Re: Shaft drive
Philippe wrote:Hi Mark
Can only agree with Philippe, I put Koni 'dial a rides' on my ST. They are vastly superior to the originals and look right.
Re: Shaft drive
Hi Paul can you pm me please ( I'm not to sure how this works )
Thanks Mark
Thanks Mark
