Gear shaft
Gear shaft
Any body know where I can get a shift linkage  shaft from or some one that can repair mine . .. please I would put a pic up but I don’t know how [image][/image]Z power have none[image6JWKT2E2TTSCZ][/image]
						- paul doran
Re: Gear shaft
Z1000st  1981
						- paul doran
Re: Gear shaft
I’ll have then matey can u pm your phone number please
						- paul doran
Re: Gear shaft
Can you put some pics please and how much
						Re: Gear shaft
Hi Tony
I don't want to steal your dream but the gear shaft of an ST is not the same as the one of a MK2. They have different numbers and they look different! Other parts of the gear shifting mechanism are different too!
Gear shaft ST: 13161-1011
Gear shaft MK2: 13161-029
Take a look at the parts on CMS.NL you'll notice the difference!
						Re: Gear shaft
Philippe wrote:Hi Tony
Correct.
Has to be an ST one for an ST.
The MK2 one only works when converting to chain drive and using the other shift shaft location hole.
What needs repairing on your ST one Tony ??
Re: Gear shaft
Hi Tony
look at this: https://www.ebay.co.uk/itm/Kawasaki-Z10 ... ition=3000
I hope this is the one you need.
						Re: Gear shaft
Yes that’s it phil, I just won it ; thank you so much
						Re: Gear shaft
Hi Tony
Great news!
									Great news!
						Re: Gear shaft
Phil iv been looking now for 3 weeks  no joy ‘. Thanks again matey
						Re: Gear shaft
Hi Tony
you're welcome.
									you're welcome.
